ANSYS SpaceClaim: What is the best method for opening an existing SpaceClaim design which includes a large number of sheets without all of the sheets automatically opening as tabs? Also if you have several designs open each with multiple sheets open what is the quickest way of closing one of the designs and its associated sheets?
June 5, 2023 at 7:05 am
FAQ
ParticipantThe default behavior is that the model will open in the state it was previously saved. There’s really no way around that the first time. If you close all the sheets you don’t need, then save the model, the following time you open it, only the desired tabs will be retrieved. As for closing, there’s no great way to do that either. You have to go through and close each tab.
- Skewness in ANSYS Meshing
