June 5, 2023 at 7:05 am
FAQParticipantThis FAQ solution is for stand alone SpaceClaim Engineer, not SpaceClaim DirectModeler In order to host a SpaceClaim license on an existing Flex server, the following items are required: 1. License file (sc.lic) 2. SpaceClaim daemon (SPACECLM.exe) Both of these files must be placed into the same folder as the LMGRD.exe file of the existing server. That server must then be configured appropriately.
