ANSYS SpaceClaim: We have a Catia V5 translator license but it does not show up in drop down list of file options. How to resolve this issue?
June 5, 2023 at 7:05 am
FAQParticipantThe CATIA V5 option requires an additional module to be installed. When you first launch the SpaceClaim installer, you are presented with 2 choices. The first is SpaceClaim, and the second is the CATIA V5 module. It’s not uncommon for a user to forget to go back to install the CATIA V5 module. Please run the installer and select the CATIA V5 option.
