June 5, 2023 at 7:05 am
FAQParticipantThis type of registration problem is caused by PC or network security settings. Make sure to temporarily disable all antivirus, antimalware, and firewall programs during the registration process. You should also ensure that you have full administrator privileges on the PC, and launch the software using Right Click > Run as Administrator
