ANSYS SpaceClaim: There are some lines, and then I do Duplicate Curves tool. Then, there are different results. One is just one line, another is multiple lines. Why are there different result? It should be the same result.
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General, geometry
June 5, 2023 at 7:05 am
FAQParticipantIf you have one long curve that wholly encloses two short curves, Duplicate curves removed curves that are completely enclosed. If two curves partially cross each other, they will split each other because we’re not sure which segment should be removed. To summarize: If curves are totally enclosed, they disappear. If curves are partially overlapping, curves get split
- Skewness in ANSYS Meshing
