ANSYS SpaceClaim: The viewport is not showing a given tool’s options when clicked; they are getting off-screen for some reason. How to get them visible?
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General
August 25, 2023 at 12:15 pm
FAQParticipantThere are 2 things to try out: 1. Reset docking layout. This option is available in File – SpaceClaim Options – Appearance. Attached image shows this option. 2. If above option doesn’t work, delete the local settings here: C:Users”USERNAMEHERE”AppDataLocalSpaceClaim This is where all of your settings are stored. Most likely you just need to delete the barlayout under the first SpaceClaim folder but deleting all of the folders here will definitely fix the issue (along with deleting all of your saved settings). If you want to save your settings for reimport you can do this in the advanced options.
- Skewness in ANSYS Meshing
