May 15, 2023 at 8:33 am
SolutionParticipantThis video shows some surface and edge operations. It shows how to stitch surfaces together form single surface body. It also shows how to remove extra vertices and extra edges. Keywords: stitch, split, extra, repair, clean up
1. 2052948.zip
2. 2052948_Captions-EN.mp4
- Skewness in ANSYS Meshing
