May 15, 2023 at 8:33 am
SolutionParticipantThis video shows how to find and remove small gaps in the surface body. It also shows the usage of Missing Faces command to create missing faces and close holes. Keywords: gap, stitch, missing faces, holes, repair, clean up
1. 2052949.zip
2. 2052949_Captions-EN.mp4
- Skewness in ANSYS Meshing
