May 15, 2023 at 8:33 amSolutionParticipant
SpaceClaim has specialized tools to repair faceted geometry. This video shows how to fix holes in a faceted geometry. It also shows the troubleshooting while fixing holes. Keywords: repair, stl, facet, triangles, holes, fix, clean up
1. 2052913.mp4
2. 2052913.zip
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
