ANSYS SpaceClaim: Project tool is taking considerable time in identifying projections. How to speed up the process?
Tagged: 18, ANSYS SpaceClaim DirectModeler, Edit Group, fluid-dynamics, geometry
June 5, 2023 at 7:05 am
FAQParticipantThe Project tool works fastest when you use the third toolguide first. The third toolguide, “Select Target Face”, allows you to only project the data onto a single face of your choosing. This limits the automated searching to determine the best face to project onto.
- Skewness in ANSYS Meshing
