May 15, 2023 at 8:33 am
SolutionParticipantPull command has different options to modify geometry. This video shows how user can create fillet, chamfer using pull command. It also covers copying and extruding an edge using pull command. Keywords: pull, copy, extrude, round, fillet, chamfer
1. 2052922.mp4
2. 2052922.zip
- Skewness in ANSYS Meshing
