May 15, 2023 at 8:33 am
SolutionParticipantWhile modifying any geometry, sometimes it is required to maintain certain dimensions. This can be done using Offset command in SpaceClaim. This video shows how to use Offset command in SpaceClaim. Keywords: offset, dimentions, length, width, maintain
1. 2052927.zip
2. 2052927_Captions-EN.mp4
- Skewness in ANSYS Meshing
