ANSYS SpaceClaim: Isnt it possible to use the skinsurface function over planes, when the stl file is shelled to inside ?
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General, geometry
June 5, 2023 at 7:05 am
FAQParticipantNo, only one surface can intersect the planes. You need to separate inside and outside surface of stl and use only one surface at a time.
- Skewness in ANSYS Meshing
