June 5, 2023 at 7:05 am
FAQParticipantThere are two different viewers. One is web based and requires no download by your client to see the model. The second is a small utility to allow viewing of models. Both can be found here: http://www.spaceclaim.com/en/Products/Addons/SpaceClaim_Viewer.aspx A third thing you could do is save out a 3D pdf which anyone with adobe can use to view the model.
- Skewness in ANSYS Meshing
