ANSYS SpaceClaim: Is there a better way to select the individual points on the spline? I tried using the middle wheel on the mouse but kept getting the complete spline.
June 5, 2023 at 7:05 am
FAQParticipantI strongly suggest using the repair tool called “Fit Curves”. Fit Curves will change the spline curves to lines and arcs which make it much easier to work with. Additionally I suggest you use the correct tangency option and don’t forget the slider bar will control how close the new curves are to the original curves.
- Skewness in ANSYS Meshing
