ANSYS SpaceClaim: Is it possible to create driven parameters in SpaceClaim? Is it possible to substitute a driving dimension for another parameter?
April 13, 2023 at 7:33 am
SolutionParticipantThere isn’t a plan today for this but it can currently be done within Workbench. If you make two parameters, you can then use an equation to link them together as seen in attached picture. If the reason they want this is for design studies I think they will be able to do this today, no enhancement needed.
- Skewness in ANSYS Meshing
