August 25, 2023 at 12:15 pm
FAQ
ParticipantIn the Display tab, toward the far right of the ribbon, you will see an option called Clip Scene Above Grid. This should toggle whether or not the geometry above the sketch plane is visible or not. Refer attached image which shows this option.
- Skewness in ANSYS Meshing
