ANSYS SpaceClaim: I’d like to section a model for visibility, but then work in 3D mode. Are there any options for doing so?
June 5, 2023 at 7:05 amFAQParticipant
Place a plane wherever you want to section your model for visualization purposes. Then right click on the plane border and go to Clip with Plane > Clip. You can reverse direction if you need to, or use multiple planes to clip if you want a more complicated section view. In the properties for the plane when you select it, you can remove the outline if you don’t want that to show. Then you can easily check the box in the structure tree to hide/unhide the plane to easily show that section.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
- Left-handed faces troubleshooting
