ANSYS SpaceClaim: I have SpaceClaim units set to mm. When I import dxf file, the units changes to inch. How to overcome this issue and have units set as mm?
August 25, 2023 at 12:15 pm
FAQ
ParticipantWhen you click File > Open > AutoCAD DXF there are some options in the dialog box. One of them is “Try to Infer Model Space Units”. If you disable that option, you should be able to set the units there. Please refer attached image which shows this option. That option should remain set after you close SpaceClaim.
- Skewness in ANSYS Meshing
