ANSYS SpaceClaim: I have created circular pattern of bodies and trying to split it using an inclined plane. The bodies are not getting split properly through the plane How to get the bodies split at plane inclination?
June 5, 2023 at 7:05 am
FAQParticipantSince all the bodies are part of pattern, they wont follow the plane inclination while splitting. To overcome this issue, before split operation select all the bodies in graphics window, right click and select “Make Independent” This will break relationship between bodies and will now get split as per inclination of plane.
- Skewness in ANSYS Meshing
