August 25, 2023 at 12:15 pm
FAQParticipantThere are a couple of options as mentioned below: 1. Select any of the offset face, right click and select “None” option from drop down list. Refer attached image which shows this option. 2. Copy – paste the body into a new session which will delete the offset relationship from the new body.
- Skewness in ANSYS Meshing
