General
General
ANSYS SpaceClaim: How to maintain thickness of the pipe but change the inner radius?
    • FAQFAQ
      Participant
      This can be done using Offset tool available in Design tab. Click the tool and then select the outer/inner diameter. After it’s set up, pulling one wall will cause both to change.
