August 25, 2023 at 12:15 pm
FAQParticipantWhen you are in the Measure tool, check the “Options” tab on the left hand side under the Structure tree. Here you can change the Display precision and set it as required. Refer attached image which shows this option. The global setting for primary precision can be found in File > SpaceClaim Options > Units.
- Skewness in ANSYS Meshing
