August 25, 2023 at 12:15 pm
FAQ
ParticipantIf you go to the Display tab there is a group called Show all the way to the right. Here you can turn on/off different entities. You’ll want to turn off World Origin. Refer attached image which shows this option disabled.
- Skewness in ANSYS Meshing
