ANSYS SpaceClaim: How to do a remote configuration for a client machine to locate the floating license server
June 5, 2023 at 7:05 am
FAQParticipantRun this executable remotely on the client machines: http://files.spaceclaim.com/SetMachineEnv.zip With the following arguments: SPACECLAIM_LICENSE_FILE 27581@[ipaddress] Example: SetMachineEnv.exe SPACECLAIM_LICENSE_FILE 27581@192.168.2.7
