Tagged: 18, ANSYS SpaceClaim DirectModeler, Edit Group, fluid-dynamics, geometry
August 25, 2023 at 12:15 pm
FAQParticipantTo create a section view of a part through two intersecting planes: Right click on the 1st plane, go to “Clip with Plane,” and then select “Clip.” Do the same for the 2nd plane. Refer attached image which shows this option. As an example, I created a cube with 2 perpendicularly intersecting planes. The above mentioned Clip option leaves the cube with a 1/4 section removed. Attached is a snapshot of this sectioned cube.
1. 2048554.zip
- Skewness in ANSYS Meshing
