June 5, 2023 at 7:05 am
FAQ
ParticipantCopying the geometry (i.e. solid, surface etc.) makes an independent copy. Copying the component/subassembly makes a dependent body called an instance. Edit one instance, all the instances update. Move the solid, all instances move. Move the instance component, only that instance moves.
- Skewness in ANSYS Meshing
