August 25, 2023 at 12:15 pm
FAQ
ParticipantText can be wrapped using the Project tool from the Design toolbar. 1. Create a plane on the face to wish to place the text on. For a curved face, you may need to use another reference, such 2 axes of the world origin to define the plane. 2. Use the Move tool to offset the plane so that it is not directly on the target face. An offset of 1 unit of length is sufficient. 3. From the Detail toolbar, click Note and select the plane created in step 1. 4. Set text size and font as desired, then define the text. 5. From the Design tab, click Project and select the note. 6. If the text is not immediately projected as desired, use the options Select Direction and/or Select Target Faces to correct the operation. 7. Click the green check mark to complete the Project operation.
- Skewness in ANSYS Meshing
