Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General, geometry
August 25, 2023 at 12:15 pm
FAQParticipantGo to File > SpaceClaim Options > Appearance ans select Reset Docking Layout. Refer attached image which shows this option. If that doesn’t work, delete everything from the following folder: C:UsersYOUR USERNAMEAppDataLocalSpaceClaim
- Skewness in ANSYS Meshing
