June 6, 2022 at 10:33 am
FAQ
ParticipantIf a linear pattern is already created, then use the Select tool to select one of the instances. You now have the option to modify Count, Spacing dimension and overall dimension. Select one of the dialog boxes for either and click on Create Group in the Groups tab. (If a circular pattern is already created, your options are Count, Radius and spacing angular dimension.)
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS DesignModeler: Weld Feature
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- How to move component within the assembly?
- ANSYS SpaceClaim: Imprinting Geometry
- ANSYS SpaceClaim: Shared Topology
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
