June 5, 2023 at 7:05 am
FAQParticipantIn the Display Tab, on the right side there are 3 checkboxes in the “Grid” Group. Toggling “Fade Scene Under Grid”, “Clip Scene Above Grid” and spinning the model 180 degrees usually results in the desired cross section display.
- Skewness in ANSYS Meshing
