June 5, 2023 at 7:05 am
FAQParticipantACIS export: All assemblies will be flattened to first level. That means components will no longer be nested within any sub-assemblies. They will all appear at the same level. Layers are also not maintained. STEP/STP export: Both structure tree and layers are maintained.
- Skewness in ANSYS Meshing
