May 15, 2023 at 8:33 am
SolutionParticipantThis video shows how material can be removed from a geometry using Pull command. It also covers some options while removing material from geometry. Keywords: extrude, cut, remove material
1. 2052932.mp4
2. 2052932.zip
- Skewness in ANSYS Meshing
