May 15, 2023 at 8:33 am
SolutionParticipantThis video shows how to cut material using Revolve command. It shows couple of instances where user can use a new face or existing face of the geometry. Keywords: revolve, cut, remove material
1. 2052924.zip
2. 2052924_Captions-EN.mp4
- Skewness in ANSYS Meshing
