ANSYS SpaceClaim: Common file types (such as .stl) as well as translator module file types (such as .SLDPRT) are missing from the File > Open file type drop-down menu. How do I get all the expected file types to show up in the drop-down menu?
- Open file type drop-down menu. How do I get all the expected file types to show up in the drop-down menu?" target="_blank" rel="nofollow" title="LinkedIn">
- Open file type drop-down menu. How do I get all the expected file types to show up in the drop-down menu?" target="_blank" rel="nofollow" title="whatsapp">
- Open file type drop-down menu. How do I get all the expected file types to show up in the drop-down menu?" target="_blank" rel="nofollow" title="reddit">
- Open file type drop-down menu. How do I get all the expected file types to show up in the drop-down menu?" target="_blank" rel="nofollow" title="facebook">
June 5, 2023 at 7:05 am
FAQParticipantWhen file types are missing from the File > Open drop-down menu, delete these items from the Registry Editor: HKEY_CURRENT_USER > Software > SpaceClaim > LicenseReset > Reset HKEY_CURRENT_USER > Software > SpaceClaim > Primary > LicenseType (To access the Registry Editor, type “regedit” into the Windows search bar, and open the Registry Editor.)
