ANSYS SpaceClaim: Can I save and export my application preference setting in a file and share with others?
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General, geometry
August 25, 2023 at 12:15 pm
FAQ
ParticipantIn the advanced options, all the way to the right, you can import, export, and clear your settings. Refer attached image which shows this option.
Attachments::
- Skewness in ANSYS Meshing
