Tagged: 18.2, FLUENT - SYS, Installation/Licensing/Systems, Remote Solve, rsm
June 5, 2023 at 7:05 am
FAQParticipantWhen using the following RSM setup: 1. RSM internal file transfer mechanism is used 2. Client and Submit host are the same machine There will be this error in the RSMJob report: “port number cannot be zero”. In order to use this RSM configuration to run jobs locally, you need to use the Operating system file transfer mechanism. Otherwise, ensure that client and submit host are two distinct machines.
