June 6, 2022 at 10:51 am
Watch & LearnParticipantThis video demonstrates how to mesh the full model by extending the mesh controls to include the modified geometry, using the named selections created in previous steps. SpaceClaim provides 3D modeling software to create, edit, and modify CAD or STL files for design, reverse engineering, simulation, manufacturing, 3D printing, and sheet metal.
Current ANSYS customers can find the BRAKE_ROTOR.scdoc model at: http://storage.ansys.com/doclinks/LandingPages/Files/RepetitiveGeometries/Landing.html
Download the BRAKE_ROTOR.zip and extract the model (BRAKE_ROTOR.scdoc) from the zip file. You’re now ready to begin the Meshing Repetitive Geometries tutorial.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
