June 6, 2022 at 10:51 am
Watch & Learn
ParticipantThis video demonstrates how to generate a mesh on a geometry with repetitive features. It demonstrates how to defeature the model to generate a coarse mesh by preparing a sector of one internal fin of the rotor to decompose it for hex meshing. SpaceClaim provides 3D modeling software to create, edit, and modify CAD or STL files for design, reverse engineering, simulation, manufacturing, 3D printing, and sheet metal.
Current ANSYS customers can find the BRAKE_ROTOR.scdoc model at: http://storage.ansys.com/doclinks/LandingPages/Files/RepetitiveGeometries/Landing.html
Download the BRAKE_ROTOR.zip and extract the model (BRAKE_ROTOR.scdoc) from the zip file. You’re now ready to begin the Meshing Repetitive Geometries tutorial.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
