Ansys Meshing fails to generate mesh on model with solids and shells with “duplicate nodes” error, how to fix issue in SpaceClaim ?
March 17, 2023 at 1:10 pm
SolutionParticipantIsolated vertex sharing between surfaces and solids are not supported. These vertices get shared only if at least one beam exists at the location. User must therefore create a beam on edge(s) where Meshing failed to mesh. Please look at attached PDF for more information.
1. 2063803.pdf
- Skewness in ANSYS Meshing
