June 6, 2022 at 9:30 am
Watch & LearnParticipantThis second video in a two part series demonstrates the use of design validation for a model that was optimized using the topology optimization capability available in ANSYS Mechanical. Topology optimization enables you to create superior geometry designs and to then validate your optimized design. ANSYS Mechanical Enterprise is a finite element analysis (FEA) tool that provides in-depth analysis of structural and coupled-field behavior in a highly productive environment for optimal engineering.
