Tagged: ansys-mechanical, ansys-student, baja, Brake Pedal, fea, fsae
June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video demonstrates how to perform a linear static-structural analysis of a brake pedal in ANSYS Mechanical. For any questions/support, join ANSYS Student Community: https://studentcommunity.ansys.com/
