June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video-tutorial demonstrates the use of the new topology optimization capability available in ANSYS Mechanical. ANSYS Mechanical Enterprise is a finite element analysis (FEA) tool that provides in-depth analysis of structural and coupled-field behavior in a highly productive environment for optimal engineering.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
