June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video demonstrates the workflow for a fracture parameter evaluation of an arbitrary crack in an X-Joint in ANSYS Mechanical. A circular surface body is used to represent the arbitrary crack. ANSYS Mechanical Enterprise is a finite element analysis (FEA) tool that provides in-depth analysis of structural and coupled-field behavior in a highly productive environment for optimal engineering.
