June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video demonstrates the use of the new SMART Crack Growth feature available in Workbench Mechanical that enables you to simulate Mode I dominant fatigue or static crack growth in engineering structures.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
