April 13, 2023 at 7:33 am
SolutionParticipantPlease refer to the attachments to access the video recording of the webinar and the slides used for the presentation. Note: Please use Windows media player instead of VLC media player to avoid issues with playing the video file.
1. 2058574.mp4
2. 2058574.pdf
