ANSYS Mechanical APDL Launcher Error The Tcl command that was executed to submit your run has failed with the following error: Error: The directory name is invalid.
March 17, 2023 at 9:00 am
FAQ
ParticipantThis error pops up when using direct shortcut to launch Mechanical APDL and the launcher is not able to identify the user settings. To resolve the error, use ‘Mechanical APDL Product Launcher’ and choose ‘ANSYS’ in Simulation Environment. Then run Ansys Mechanical APDL. This step will use fresh settings and resolve the error.
