June 3, 2022 at 1:43 pm
Watch & LearnParticipantThis video demonstrates the set up and analysis of user defined representative volume elements (RVEs) in Material Designer. A rotor in an electric motor is used as the example.
- Introduction to ANSYS Material Designer
- ANSYS ACP: Lay-up Mapping of a Composite Spring
- Ply Staggering with ACP – ANSYS Composite PrepPost
- Ansys Material Designer – User Defined RVEs (Representative Volume Elements)
- Variable Material Properties Calculated in Material Designer
- ANSYS Material Designer: Calculating Variable Material Properties
