June 3, 2022 at 1:43 pm
Watch & LearnParticipantThis video shows how to calculate the material properties of a woven mat that is draped over a half sphere.
As the fabric is draped over a doubly curved structure, the fabric is sheared and the fiber directions change. For this reason, we need to determine variable material properties as a function of the shear angle.
- Introduction to ANSYS Material Designer
- ANSYS ACP: Lay-up Mapping of a Composite Spring
- Ply Staggering with ACP – ANSYS Composite PrepPost
- Ansys Material Designer – User Defined RVEs (Representative Volume Elements)
- Variable Material Properties Calculated in Material Designer
- ANSYS Material Designer: Calculating Variable Material Properties
