March 17, 2023 at 1:11 pm
SolutionParticipantThis document will present an error linked to the “ANSYS License Management Center” webpage. ERR_SSL_PROTOCOL_ERROR
1. 2022.R1_ANSYS_Licensing-Server-Web_Browser_Error-2067417.pdf
